1 - 8 of 8 Posts
Looking for a writeup for swapping out the ignition system on a JDM H22A. The engine I have has a internal coil. I would like to transform it into a external coil setup using MSD equipment. Anyone know where I can find a writeup?
My setup will be MSD wires, MSD distibuter cap, MSD Blaster SS coil and either a MSD 6AL or SCI.
That's exactly the same set up that I have on my JDM H22A. Blaster ss coil, MSD distributor cap (to take the external coil) and the MSD Digital SCI+
A friend of mine helped me wire the coil, as I know nothing about electrics. From watching what he did, it's a very simple job. Basically you have to extend 2 wires out of the distributor to go to the external coil, and remove the internal coil. I'm pretty sure it shows you what wires you need to put in, with the instructions in the Blaster SS Coil.
If you're still stuck, drop me a mail to [email protected] and I'll tap my friend up for some advice.
check out:
http://www.c-speedracing.com/howto/msdbtm/msd.php
or
http://www.************.to/articles/install/msd6.html
^^ hahaha, i cant believe they censored out "honda prelude" (no space)
I forgot where i found the article, but you can convert your stock cap to accept external coils by drilling into it, and placing a MSD "power tower" or "tower converter", basically a nipple, onto the cap. You can also buy MSD caps for the H22 that has been pre-modified for an external coil. Check out the two links first, it might be what you're looking for anyways.
1 - 8 of 8 Posts
