anyone got it? u like? and performance diff?
performance gains? you wont get any at all.. its like saying mugen valve cover.. you wont get anything from it..LudeAction said:anyone got it? u like? and performance diff?
yup a big waste of money.. i recently saw a mugen "high performance" as they put it, radiator cap.. sheeshLAblue said:
lolz more like saying geting gains from gauges![]()
www.kingmotorsports.com
This thermostat has the operating temperature set lower than normal. It prevents engine power loss by minimizing rapid water-temperature rises under harsh conditions such as during circuit driving. The use of a flow-control-type valve prevents hunting, thereby achieving rapid stabilization of the water temperature (the engine warms up within a short period).
Operating temperature: 68°C (STD.: 76~80°C)
Full-throttle acceleration temperature: 83°C (STD.: 90°C)
Activates cooling fan at 80°C instead of the stock 93°C. Requires use of Mugen low-temp thermostat.
how does the t-stat change the temperature in which the engine runs? how is a t-stat and a fan switch going to help your engine cool once your coolant reaches 200 degrees??? if i driving down the dragstrip how is the switch and the thermostat going to help? if im wrong explain...burban33 said:Despite what you typed, a lower temp thermostat does change the temp in which the engine runs. The fans and the thermostat are what regulate the engine temp.
it sounds like you are just regurgitating what people are saying on other boards... it "should run cooler", but will it???If your cooling system is in good condition then your car should run cooler. As far as performance gains I am not sure but I'd say it is definitly a worthwhile investment in that it would be beneficial to the engine.
for once, i agree with what you are saying...LakeMountLude said:yes lower engine temps means more power cuase of the lower intake temp.. but see the thing is, is just because it opens up earlier doesnt mean it keeps your engine cooler overall.. it just keeps it cooler in the beginning but will eventually get just as hot as it normally would
and they say placing the "tornado" in your intake will give you 20 hp...LudeAction said:theysay its 20 degrees cooler even after racing for a while
