Ok, I bought a 1/2 body 95 DEL-SOL SI, I had to buy almost everything and assemble. I couldnt find a Z6 that it came w/ so threw in a D15-B7 for temporary usage.... Now that its all together, it'll crank but wont run unless ur spraying starting fluid in it, also it runs more than 15sec's if I choke the throttle body. I have tryed everything and I'm at a loss. I've installed a new fuel pump, and filter. Like I sd it's gettin fire or it wouldnt run on Ethyr. Also, a friend of mine hooked sum kind of light to the injectors and when he hit the throttle it got brighter so he sd the TPS was working properly. I have a PO6 ECU which is for the D15. Please sum1 HELP?:confused
