My check engine sing is on - i reseted the ecu, it goes away and after a long drive the sign comes back on. I'm so fucking pissed
what should i do?
i changed the plugs and the wire already! :mad:
on the passenger side...remove the plastic panel that protect the ecu(close to your right foot..:confused: )
and check for a little connector with only 2 wire and bingo!
Jump the connector with a little wire or a clip...and put your key at ON...
The check engine light will flash....
long flash are 10
short flash are 1
So the code 45 is: long-long-long-long----short-short-short-short-short
Do this and come back here to tell the code
:tu2:
