My Civic HB Weighs 3275lbs
864 Views 8 Replies 6 Participants Last post by  sKzoFrENiX
Is this some kind of misprint, because in the drivers door jamb it says the car weighs 32XX Lbs, If nobody beleives me I'll rip it off and scan it. Is it wieghed in Kilos or something?, because I posted earlier about HB's not being much lighter and everyone said that they weighed like 2200 lbs, but for real, mine says it weighs 3225... yes that's Three thousand, two hundred and twenty five pounds.
That's probably the GVW. I'll look it up for you...BRB ;)
Curb Weights
'96 CX hatch:
Manual = 2238 lbs
Auto = 2304 lbs
'96 DX hatch:
Manual = 2253 lbs
Auto = 2319 lbs
Thanks man...
The GVW is what I thought the wieght was, what is the GVW??
Thanks man...
I should have said GVWR
CURB WEIGHT refers to the weight of your vehicle, including fuel, coolants, lubricants, emergency tools, spare tire and can include any equipment that is standard. It does not include cargo, passengers or other options installed by the factory, dealer or aftermarket supplier.
PAYLOAD is the maximum weight of cargo, occupants and optional equipment that your unit is designed to carry. It is the GVWR (Gross Vehicle Weight Rating) minus the base curb weight.
GVW (Gross Vehicle Weight) is the curb weight plus everything you have added such as cargo, passengers and optional equipment that is being carried at any given time. If you add more cargo or passengers than your GVW is what you weigh now.
GVWR (Gross Vehicle Weight Rating). This is the maximum weight of the vehicle plus everything added that the manufacturer designed your unit to carry.
GAWR (Gross Axle Weight Rating). This is the carrying capacity for each axle your unit has. Both the GVWR and GAWR are listed on your safety compliance certificate posted in your vehicle. The rating is based on the carrying capacity of the lowest rated axle and suspension component. This is why it is so important to know and observe vehicle loading rates.
GCWR (Gross Combined Weight Rating). This is the maximum combined weight of the towing vehicle AND the towed vehicle, including passengers and cargo.
from wut i heard and wut i did is ...u get the gvw or wytever and u subtract it from the payload or wut ever its called the thing that tells how much the car can carry...its like 3600-860 i think it is ...and u'll get somthing like 2200-2300lbs
hey Evolution im selling my si wheels wraped in kumho's ...hit me up on AIM:jdmcivic718 aiight
Out of curiousity, how much would brand new Si wheels cost? Can you buy them from Honda/Honda part retailers?
crooklyn what u want for those Si wheels man?
im looking for a set 4 my hatchback... (i got no garage, anything else invites thieves too much):mad: a lesson i had to learn twice with my CRX :rolleyes: anyways im interested how are the wheels condition wise, ever curbed any of them etc?
