Yeah dont let the wax confuse you. This shine was achieved using other products beforehand. The wax is see through and just enhances that shine.
S100 is good and easy to use but also doesnt fill in things like others do, nxt and such....nxt helps make it appear even more perfect.
But S100 if used on a well preped surface will look very nice.
I suggest getting a polish and pre-wax cleaner beforehand for ultimate results. Heres a good process.
NXT Wash , Mothers Clay Bar , #7 , S100 Shine Enhancing Lotion , then S100 Wax, Your car will look totally different with this setup.
If it needs more work. Do something before thats stronger Ill try to find something locally that would work. Im thinking you could at least try the deep crystal cleaner. But thats not really too aggressive.
Also if the paint still isnt so hot. You can also work in NXT WAX before the S100. This will cover up all the imperfections...but probably will remove the shine enhancing lotion. Then apply the S100 like an hour later if possible...to let the nxt set.
You can also subtract a few things. Try out just a few products. Wax is intended to seal in the polish work you have done basically and protect it from elements as well add some shine , depth etc.
