hey guys... hopin you can lend a hand here. i've finally decided what i want to do with my car and i have a couple questions.
i've got an 88 rex dx, with the d15b2... instead of doing a b series swap, i've decided to make a mini-me setup by keeping my existing block and doing a transplant on the head. gonna go with a d16a6 from my local yard and have it rebuilt.
here's the questions...
1. what other parts do i need to get from the yard? my car's currently dpfi.
2. when rebuilding the head, what parts should i have replaced? i'm guessing a new cam (from who?), but from there i have no clue.
3. does anyone make a better piston for the d15b2 block? i want decent compression, but i want to remain on pump gas without problems.
4. what are your opinions on msd's sci system? is it worth picking up, or is it a waste?
5. would a daily driven car benefit from an oil cooler?
thanks for your patience guys, i know it's a lot of questions but i definately appreciate your time and help.
I haven't done any swaps, but i've read alot on d series swap's. The mini me sound like a really good, cheap, and easy swap for a newbie mech. . Mpfi swap is good too if u haven't done it already? For mini me you might want to consider a mpfi swap or get a fuel management system, to increase fuel when vtec kicks in. Piston's I would rec. using stock cause of the high cr on mini me. If any thing lower comp. pistons. Haven't tryed oil cooler and i hear ignition r only needed on fi motors.
Am I mistaken or is the A6 Intake manifold MPFI? Or you could get a y8 IM, but i dont know about wiring.
You may also need to use the a6 timing belt.
http://www.hadamotorsport.com/D16camshafts.htm
check if the head is warped, maybe have it machined.
Search the forum and find that piston page that guy made, shows compression height, bore, and dome/dish for most/all dseries pistons...nevermind http://www.heeltoeauto.com/dseries/dseries1.html
didn't Bisi run stock ignition on his Dseries and Fseries engines? Doesnt that msd system cost around 300 bucks?
??? dont know??? I know my 86 corolla gt-s with a 4A-GE has one though.
D-series info
http://superhonda.com/forum/showthread.php?s=&threadid=129124
a6 doesn't have vtec, and i believe a6 injectors are 240cc
Try to get a hold of a crx Si tranny, or a civic ex tranny (92-00)
Please correct me if i am wrong
