hello, i have the AudioBahn A2502DP 2chan amp
and i'm in need of some subs
here is the ratings for it
Number of Channels: 2
RMS Power (4 ohms): 250 watts x 2 ch.
RMS Power (2 ohms): 500 watts x 2 ch.
RMS Power (1 ohm): 750 watts x 2 ch.
Bridged RMS Power: 500 watts x 1 (4 ohms); 1000 watts x 1 (2 ohms)
Peak Power Output: 3000 watts approx. (1 ohm)
I was thinkin' of getting the AUDIOBAHN AW1251T (2x) in a bandbass enclosure but someone said they not that good?
heres the specs
12" VERY High Performance Subwoofers
800-watts MAX Power Handling
400-watts R.M.S. Power Handling
Embossed flame design on magnet
45oz Strontium Magnet
Freq Response: 30Hz - 1kHz
Efficiency: 91.1dB
PHat Foam Surround
Poly-Coated 2 Layer Non Pressed Non Transfer KM3 Coated-Cone for Virtually No Cone Distortion
2" four Layer Black Aluminum Voice Coil
Nice Dual 4 Ohm Voice Coils
2 Ohm or 8 Ohm Operation Each one
The Mounting Dimensions: Depth; 5 1/4" Hole; 10 7/8" Diameter; 12 1/2"
Nice Lug Lock Terminals
if ne1 know any good subs that will fit those amps please help
also enclosure to go with the subs
thanks!!!
With 1000rms x 1 at 2ohms I'd go with a single 12
Image Dynamics IDMAX
JL 12W7
RE Audio XXX
Orion H2
Kicker 12L7
something like that would be tons better than the 1251T's,I had a set of these subs about a year and a half ago and the sound quality of them is pure shit and they do not get loud enough to justify the lack of sound quality.
if you are wanting 2 12's look into
Alpine Type R's
Memphis PR's
Cerwin Vega V-Max's
JL 12W3's
what all do you have to spend,are you willing to buy off ebay?
thanx for the input
if i wanted to go dual Kicker Solo-Baric S12L7 L7 12" Subwoofer could i still use that audiobahn amp. or will i be singing "BOOOOM, goes the amplifier...." :bye the amps are rated @ 500w RMS x2 still shy 250W RMS would that kill the amp? or amp just wont fully utilize the subs power? and run 'em as 500w subs each?
would dual sound better than single sub?
and single would be going into this enclosure http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=5742527058&ssPageName=STRK:MEWA:IT
just a matter of how im gon keep it from moving around in the trunk
this is what i plan on buying as setup
HU: Pioneer DEH-P860MP $415.00
Front speakers: DIAMOND AUDIO M661 6.5" $220.00
Rear speakers: Diamond Audio CM361 6.5" (filler) $155.00
Amp Kit: Rockford Fosgate 4-Gauge Dual Amp Wiring Kit $175.00
4-chan Amp: KICKER KX800.4 amp (800w) $235.00
2-chan Amp: AudioBahn A2502DP True Digital 1000RMS watts 2-chan $220.00
Sub: Kicker S12L7 12" 750w RMS
Sub Box: Kicker Box $50.00
[edit]
i'm willing to spend $1500 +100 if i have to
will be ordering piece at a time receiver first, speakers, 4chan amp + amp kit, 2 chan amp, sub + box in that order
Discussion Starter #4
i was just looking at the S12L5z 600w RMS
maby i should go dual with these? $290.00 shipped for 2 kicker S12L5s
The L5/L7 is a good sub but IMO a bit outdated as you can get around the same output with a different sub with it taking less room and power while still retaining better sound quality.Subs are totally different thing than 5 years ago,there are a lot of companies that are not mainstream that you get a hole lot more for your money.
http://www.ascendantaudio.com/Atlas 12.htm
http://www.oaudio.com/TC2_PLUS.html#specs
these are starting to make a good name for themselves also email or call www.reaudio.com about a SX12 or a pair of SE12's
Discussion Starter #6
ok if those are too old what do you guys/gals recommend? i got $400.00!!! to spend shipped for subs
and thats for 2x 12" subs max RMS 500w thats what the amps put out and needs to be 2ohm configuration
