Water pump, Timing belt, Balancer belt, 1 tube of RTV, Valve cover gasket kit, a set of feeler gauges for adjusting lash on valves. all totals to about 100-150 bucks.
To replace the timing and balancer belts is easy, its really not that difficult, however when you do this you must replace the valve cover gasket. 800 fucking dollars? that is crazy talk. Find someone with some basic tools, the worst thing you'll encounter is the crank shaft pulleys bolt, which requires a 19mm socket, perferably one that is 6 a point style. and a hefty breaker bar, or impact wrench.
A link to a downloadable shop manual for your accord(which is 1300+ pages) is on this site.
Man up and do this yourself for about 1/4th the cost. You'll learn alot.
Here's a basic breakdown of what you'll need:
1 descent floor jack and 2 jack stands.
Socket sets with wrenches of 1/4' 3/8' and 1/2' drive, some small extensions maybe some converters from 1/2' to 3/8 and 3/8' to 1/4'
10,12,14 mm sockets for all of the drive wrenches, and deep wells if possible.
The water pump does NOT have to be replaced when you do a timing belt change, however it is considered to be preventative maintainence, and just a good idea considering your already in there and the pump isn't that much.
This is all fresh in my mind as im currently doing the exact process your talking about.
If you study the manual thats available through the stickeys in this site and really learn what items you will need to remove what bolts go where etc this install will be very easy, so long as you can follow directions.
I like to use my laptop by my car and keep the PDF file up on it for a quick refrence.
Most of these tools , if not al of them, can be rented from an autoparts store, which youget al the money they cost back upon returning them.
For a complete novice I would expect the install to take roughly 15 hours of your time doing it solo, which includes cleaning the stubbron old gasket out of the valve cover.
Any other questions?
