Can you use B16a1 cams and caps on a GSR head.
Also GSR head that I have has no cam caps. Can i just buy some other used one and use that or do I need the original ones. If not can some one please help me.
all b-series vtec head parts are the same the caps the rails the bolts so you can use whatever ones you have
Discussion Starter · #5 ·
okay now if all cam towers are specific just for that head, where would I be able to have some made so I can use this head. Beacuse I can always buy aftermarket cams. Thanks for the info
Hondaid said:
Personally I wouldn't suggest doing that. The Cam Towers are machined to match the head. They're kinda specific.
if thats what you believe then your wrong ive clearanced the whole head with 4 sets of cam caps from 4 diffrent heads and they were all the same
