Directly out of the tank - not off of the line coming from the in tank pump. The regulator depends on the fuel pump - some require some do not. If it does - you can tee your fuel return line and feed it back through the factory return AFTER the stock FPR. Plumbing a BADASS nitrous system is half of the fun with spray. But it is also 3/4 of the hard work. Once you get it right - You shouldn't have any problems in the future.
HENRY
HENRY
