I want some suggestions on some good tire cleaners. I ran out of the stp son of a gun stuff which is probably from 1998.
I prefer something other then foaming stuff and nothing that will crack or ruin the compound of the tires.
I already have some meguiars high gloss, just need some cleaners. I've been looking at Eagle One, Meguiars, Mothers, Black Magic, Armorall, etc... Any recommendations?
Also, I have some NXT Tech Protect that i use for the interior. Bottle says it works with rubber/tires, is it safe?
So you're looking for a cleaner, not a shiner right? Any tire cleaner would work fine, as long as you have a tire scrub brush. I've been using the Advanced Auto Tire Cleaner as of late, and it works well.
I used to have a bottle of Griot's Garage tire cleaner, that stuff worked wonders as well.
As long as you have a good brush, I think the cleaners will work about the same.
i used bleach white and a brush to clean my tires, then I spray it off after I brush the tires w/ the bleach white. Then I used tire shine. Works really well.
btw...if you tires are cracking..you might need to replace them. but i just use miild soap on my tires...works wonders. but all tires get harder to clean over time. just a tire with less groovese in the sidewall..IE...not Kumho 711...and maybe Flaken Azeni or BFG gforce kdw nt
Premium Member
NXT Tire Cleaner
another
Simple Green Extreme
Then the topper.
High pressure washer.
All of these are good at getting those tires nice and clean.
I then use nxt tire shine. Stuff lasts forever , comes easily out of aerosol can.
But yeah take any of the cleaners above , then use the high pressure washer and youll have the cleanest , blackest tires around.
