on my JDM b16a2 redlined at 3ed gear the car went into limp mode when i pulled the code it was 4 cps reset the ECU but still code4
opend the distributer found brownish red dust in it .. which means the bearing went in my distributor !! which lead to over heating of the sensor
went to a mechanic to replace it told me it was ok !!!!
so is it still the sensor?how can i b sure? is there any othere reson for that sensor error?
a week ago i changed the timming belt maybe the guy didn't tighten it up right how can i know if the belt is inplace right !!
the problem is that your vehicle has jumped timing my car was doing the same thing. reset the timing and it went away. The cyp sensor is in the distributor and thats why the 4 code is coming up.
