I have a '94 Accord Ex 5spd, and i was trying to make the High Beam Light to turn on alone without the low beam being on and somehow i guess it just make all of my fog lights, corner lights, and taillights off, it wont come on when i have it on, on the first light up stage (parking lights) but the low & High beam works plus the signal but not the others, I need help, any ideas?
Undo what you did and use some relays up by the headlights. Disconnect them and make it so the normally closed circuit is low beam and the triggered open circuit is high beam... when you click on the high beams and the high beam input from the car hits into the relay, the switch will jump to high beams and open the connection to low beam. Kinda confusing if you don't know relays well, just find someone that does and pay them :D
