1 - 10 of 10 Posts
i have a 4 fogger 100shot direct port and 190lph fuel pump .everytime i spray it kik me right in the front, its like the engine stall for a milisecound then kik me right in seat
only the first gears i spray is doing that shit then no more bog all the way the 1/4 mille
plz help:confused:
are you clearing the lines? (purging) all the shit out, that can cause that .
BTW , you got pics of the set up? im curious to see how you did yours?
sorry i have no picture
i just found that the bog is comming from fuel!
ive made only a fuel shot whit no nos and made the same bog (of corse of only fuel injecting made almost car die )
does (nos purge kit) only purge fuel?nos or both?
thx for helping
just purges n20.
if ya want a purge solenoid u can buy this one from me....
brand new in package..this was a display one:
have fun w/ this :D
? wow , you got me now . is your fuel pump in good cond? check for leaks? i dont know why the fuel would do that unless the line is clogged or something
Normal
I don't have a purge kit but mine does the same thing.
p.s. Hello everybody, I'm back:D
welcome home . :D
Thanks
welcome home .
Thanks man!! I will try to come more often. I just been really busy (new job, new hometown):D
it's most likely the short period of time from when you open the solenoid to when the N2O has an effect on the motor. at times i can feel this in the first gear i inject in, whether it's first, second or third. i don't have a purge kit and don't really need one. i don't mind a second delay of injection. sometimes it helps me use it in first too though i still lose traction.
BTW i'm using the NOS DP kit on my B18C1.
later
with nitrous there is one pesky problem, sometimes there isnt enough nitrous in the bottle, this gives a rich condition and that bogs down the engine. always purge till you get a nice cloud of white smoke, nice and healthy cloud, pretty pretty cloud of nitrous, oooooo that will cure all problems.
1 - 10 of 10 Posts
