I need to know everything you need to do a civic type r motor swap in a 96 civic hatch. I have the motor and wiring harness and ecu but what else do I need? Any help will be graet. Thanks
you will need 00si mounts; the back and front two. i believe u could use the other main mounts in the front [sides]. any b series axles will work - integras, civic si, delsolDOHCvtec. you will also need to run vtec wires.mugen civic said:I need to know everything you need to do a civic type r motor swap in a 96 civic hatch. I have the motor and wiring harness and ecu but what else do I need? Any help will be graet. Thanks
