Okay I've searched for this stuff and I can't seem to find it.....
first thing first, what is the eg, ek, or ef. I have a 95 sedan civic wha's that?
I need a parts list for a h22 civic swap, I mean everything. including A/C keeping stuff.
uh well your car is considered an eg since thats its japanese chasis code. but the amreican civics are diff. for example, my civic is an EH3 which is a Si, and other 5th gen civic is classified as an EH2. I found this article on Honda Tuning. they got the other 2 parts in their tech section, so i hope that helps out. good luck with your swap! :tu2:
The basic chassis code is just two letters (such as "EG"). the number suffix next to it indicates the engine the car has, & also (sometimes) what body style too.
For example:
EG6 = DOHC VTEC SiR/SiR II hatchback
EG9 = DOHC VTEC SiR sedan
It changes with the EK:
EK4 = DOHC VTEC SiR/SiR II hatchback
EK4 = DOHC VTEC Si/Si II sedan
As you can see, they decided to retain the same number to indicate the engine for the EK series. Unlike with the EG6 & EG9, if only "EK4" is quoted, then you only know what engine the car has, as the body style is a mystery.
Hope that helps & doesn't confuse you further.
