Hi, i currently have one 30 INCH blue neon on my rear, and a 10 inch one in front by the HONDA sign where most people put their grills.
Now, my wiring is messed up. A wire is cut somehow and nothing is working.....i do have a switch that I need to use. THing I need to ask you guys is:
Ok, I probably will buy 2 more neons, probably 15 inch each and attach to the sides near the doors and then re-wire whole neons. How much should it cost to wire 4 neon lights to a switch plus install those 2? I wanna spend max $100.
I thought about this just now because I don't have enough $ for headunit and i was saying to myself: "Hey wtf, my neon lights are just sitting there not being used!!! Lets make em work!".
Umm, not sure why you have neon lights on the outside, but hey free country right? Stuff like that is illegal around here, so I am guessing you live elsewhere than PA. As for wiring, since you can't really see the lights unless its dark out, did you ever think to wire them to your parking lights or even headlights, so that when either of the 2 is on your neons will be too? I used to have neons in an old stereo install, and what I did was wire all of the neons into the trunk light's wiring so that when you opened the trunk they would come on. If you still want to go with the switch route, it shouldn't cost you more than 10 bucks. All you need is one switch, and enough wire (guessing like 14 or 16 guage) to run to the locations of your lights.
Hey thanks for the suggestion. Pretty interesting stuff....i was thinking about wiring 2 10 inch neons inside, right where your go. Those would turn on if I would turn my LIGHTS ON and the 2 other neons outside would be turned on if I use my switch.
Well I live in CA, but I am pretty careful to not turn them on around cops. hehe
Cya
15inch neons on the sides, that will not be long enough, thats what i have under my dash and it just fits!
You will want those 30 inch neons on the back, on the longer ones not sure how many inches they are but they would go on the sides!
If your gonna buy 15inch neons but them under the dash!
