1 - 10 of 10 Posts
to avoid running extra lines, pull the entire wiring harness from the car your getting the new engine from, if your just buying the engine, malke sure it has the wiring harnes with it, including the ecu, that way you can just drop the motor in, plug it all up and plug in the ecu....boom, done.
DriftKingB18 said:
drop in an old V8 and call it a day
why dont you do the 302 conversion on your miata????
DriftKingB18 said:
because I can make it alot faster for much less $$$$ and still pass smog
i dont know man, the 5.0 has alot of potential, way more than your 1.8 in your miata, but it wont pass smog, so yours smart for that.
1 - 10 of 10 Posts
