i'll offer my thoughts...
put em on the front, if you put them on the rear, your just inducing more understeer and less rear rotation. Plus, more traction for the drive wheels. I am assuming you set the shocks to "1" because of the sportlines, they are softer than the pro kit. I am also assuming "1" is the stiffest setting. With the stickier front tires, you may want to try softening up the front one notch.
I'm not familiar with the civics subframe brace you mentioned, but if its any type of X or cross bracing, you move up from STS class, if that is infact the class your going to run in. But your other mods are fine for STS class.
