Whats up guys? I am new to this board but not to this sport. I have a B18A non vtec motor. Does anyone have any forged pistons for sale? I am looking for 9 to 1 comp pistons for a stock size cylinder bore. I have finished my turbokit already now I am in the process of building up my bottom end. My plans for my bottom end are:
stock rods shotpenned (ARP rod bolts)
forged piston
sleeved block
Type R oil pump
ARP head studs
I already have:
JG head fully ported and polished
JG 1001 cams
JG stock intake manifold ported
JG throttle body
Custom turbo manifold
T3T4OE turbo
Richard Lee wastegate (supports over 800hp)
Custom front mount intercooler
2 1/2" intercooler piping
B&M adj fuel pressure reg
Vortech FMU
AEM cam gears
B16A J1 tranny with LS 5th gear
stock flywheel lightened from 18 pounds to 13
Aluminum crank pulley
2 1/2" exhaust
Buick Grand National fuel pump ( fits intank and supports up to 400whp)
PYR ecu with upgraded fuel & spark curves rev limiter set to 8600rpm but I shift at 7300rpm
Clutch Masters stage3 pressure plate & clutch
HKS blowoff valve
Feilds Vtec controller
I am unsure of injector size and ignition upgrades.What hp numbers can I expect and what problems do you see with my setup that needs tweeking? Any help would be greatly appreciated.
forged piston
sleeved block
Type R oil pump
ARP head studs
I already have:
JG 1001 cams
JG throttle body
T3T4OE turbo
Vortech FMU
AEM cam gears
2 1/2" exhaust
HKS blowoff valve
