1 - 14 of 14 Posts
hello,
I bought a honda accord 1995 EX.The engine code of it is ((F20B2)) non vtec.
Can any one give me some inforamtion for this engine??How much hp/tq?
some pics for the engine.sorry about the pics because its in bad quality...
Also I have another question...
Will h22 fit my car or I need to change something??
thanks...
Something isn't right here. You sure its a F22 instead of a F20. I never heard of a 95 accord having that engine code. Last time i checked the F20B2 is a DOHC vtec engine from the accord Si-r.
Year Model Engine Generation Displacement CC's Compression Ratio Horse
Power Torque Country
94-97 Dx / Lx F22B2 5 G - CD 2156 8.8 : 1 130 @ 5300 rpm 139l b/ft @ 4200 rpm USA
94-97 Ex F22B1 5G - CD 2156 8.8 : 1 [email protected] 5500 rpm 147l b/ft @
4500 rpm USA
94-97 Si R H22 5G - CD 2157 10.6 : 1 [email protected] 6800 rpm 152 lb/ft @
5500 rpm Japan
90-91 F22A4 4G - CB 2156 8.8 : 1 130 @ 5200 rpm 142 lb/ft @
4000 rpm USA
90-93 F22A1 4G - CB 2156 8.8 : 1 125 @ 5200 rpm 137 lb/ft @
4000 rpm USA
91-93 F22A6 4G - CB 2156 8.8 : 1 140 @ 5600 rpm 142 lb/ft @
4500 rpm USA
90-93 2.0 Si F20A 4G - CB 1997 9.5 : 1 150 @ 6100 rpm 137 lb/ft @
5000 rpm Japan
88-89 A20A3 3G - CA 1955 9.3 : 1 122 USA
______________________________________-
i think his is f22b
EDIT from TOPEND MOTORSPORTS
F SERIES ENGINES
Engine:f20b
Year: 90-93
Trim: SiR
Hp:200
Tq:146?
Displacement:1997cc
Compression:11.0:1
Valvetrain:DOHC, VTEC
Engine:f20a
Year:90-93
Trim:2.0 Si
Hp:150
Tq:137
Displacement:1997cc
Compression:9.5:1
Valvetrain:DOHC, NON VTEC
Engine:f22a1
Year:90-93
Trim:lx/ex
Hp:125
Tq:137
Displacement:2156cc
Compression:8.8:1
Valvetrain:SOHC, NON VTEC
Engine:f22a4
Year:90-91
Trim:dx?
Hp:130
Tq:142
Displacement:2156cc
Compression:8.8:1
Engine:f22a6
Year:92-93
Trim:ex
Hp:140
Tq:142
Displacement:2156cc
Compression:8.8:1
Engine:f22b1
Year:94-97
Trim:ex
Hp:145
Tq:147
Displacement:2156cc
Compression:8.8:1
Valvetrain:SOHC, VTEC
Engine:f22b2
Year:94-97
Trim:dx/lx
Hp:130
Tq:139
Displacement:2156cc
Compression:8.8:1
Engine: f22b (JDM Prelude)
Year: 92-96
Trim: Si
Hp: 160
Tq: 148
Displacement: 2156cc
Compression: 9.0:1
Valvetrain: DOHC, NON VTEC
Engine:f23a1
Year:98-02
Trim: LX/EX
Hp:150
Tq:152
Displacement:2254cc
Compression:9.0:1?
Valvetrain:SOHC VTEC
Engine:f23a4
Year:98-02
Trim: LX/EX
Hp:148
Tq:153
Displacement:2254cc
Compression:9.0:1?
Valvetrain:SOHC, VTEC (ULEV)
Engine:f23a5
Year:98-02
Trim: DX
Hp:135
Tq:153
Displacement:2254cc
Compression:9.0:1?
f22b1...two sites cant be wrong...can they?
Discussion Starter #7
am not from the USA..
In my country some accords doesn't come with vtec..
I think that the car was wrecked before and the engine was changed because 95 accords comes with 2.2 not 2.0!! what do you think about that??
I got a h22 engine with 5-speed Tranny...I go to a car mechanic and he will swap the engine from non-vtec to a vtec and auto to manual for 2600 dollars :ninja and I dont have a money for swapping.So can I follow the instruction in this thread http://www.superhonda.com/forum/showthread.php?t=164067 or what??
yes, but bewarned it is very time consuming and make sure you have a ride to a nearby honda dealer or a car parts store cause things dont always work out perfectly.
if you really heart your honda (love your honda) then you would not be so lazy. You would instead go search for the f20b2 and then search for h22 and so on and so forth.
SO in conclusion, heart your honda? Good, now put the words to rest and put the actions forward and use the search engine and read more to learn more to heart more.
chanvan said:
hey are you sure the torque is right on the f22b1? cause 147 sounds a little high
The tq figure is correct, the f22b1 sits at 145hp/147tq and can be bumped up slightly with boltons and ecu reset, get more with boost, get a lot more with nitrous and a crap load more if you are a trailer queen with a big snail bolted down.
DUD..what ya have here is a middle eastern version(in our case GCC countries),,,non of those went to the usa as they are inferior ..a 2.0 non vetec (sohc and non v-tec 2000cc capacity) so non of the folks here can answer ya...unless someone imported this engine from say like..Kuwait or UAE... i can tell you why they asked ya : ARE You sure it is badged as f20b2..why hell i knew immedaitly ya had the same engine as mine,,,its not the same f20b2 they know which is JDM...
GCC-spec: gulf corporation countries spec but,,,it is also sold around it or somewere close by,,,,
you are having the same issue i had before when i was trying to find out what do i have in my car..,,other issues like what turbo kit to get for it,,non of those were able to help me,,again,,this engine is dawn graded for extreme desert conditions..
no ya car is normal..it not been altered or engine changed ya have the same engine i DO...my accord is is a 1997 honda accord F20b2 exaclty the same as yours (checked your photos.)
best thing about that motor is that it revs in a blink fast compared with f22 accords (imported from usa) but lacks output
IMPORTANT BEFORE You POST back : its not the JDM f20b2 with the blue valve COVER on top of it ..it is completely Grey block and lowest grade accord ever had.....witch is why it was not imported to the U S A...
. but rumor say that it is barly 110hp or even less (my advice if ya want to upgrade then swap the engine for a f22 or h22) :aww
the F20B2 THEY KNOW :
F20B2 - 200hp, DOHC, VTEC, 8300rpm Redline, from 94-97 JDM Accord Si-R
the f20be we have here is :
F20B2 - ???hp(you dont wana know,,lol), sohc , NON-V-tec.6300RPM redline.from 94 -97 (gulf spec) accord EX or lx
no v6 (2700cc) offerd in these areas..and god bless
email me for spec sheet..
hey can i get the spec sheet i have the same car as well and im curious
1 - 14 of 14 Posts
