well I just bought a 92 hatch, though not shure which modle it is but it has leather. Any way the head gasket is gone as well as the thermostat. Instead of fixing it im planing to buy this d15b
and i just wanted to clarify that to swap this moter into my civic all i need is the ecu and thats it right every thing else is the same as in: mounts axles ,wiring harness and the tranny i can just use the ones that are on the civic right ?
also any imput or suggestions would be appreated thax
http://www.hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30019
thats the motor i plan to purchase
What engine do you have right now?
The d15b is an awesome motor, but if you have a d16z6 it might be worth it to just repair it. The d15b puts out a few more ponies than the z6, but the z6 has more displacement giving it more potential...and a slightly longer stroke giving it a more linear powerband.
A headgasket shouldn't be too hard as long as you have a decent manual, and the thermostat takes like 10 min or less.
Discussion Starter #6
thx for the info its not an si so ill probably go with thw d15b or posibly a d16z6 im still kind uf stuck up on it
