1 - 10 of 10 Posts
Look around the area under the master cylinder and such. I always see little rubber plugs on the firewall no matter what kind of car it is.
I ran the wire for my system through the one by the fuse box too. If you can't fit it through, you can make a small incision in the rubber, then feed the wire through. It's not hard, just move the carpeting on the passenger side, and then i straightened a coat hanger and put it through the rubber seal and fed the wire through that way...good luck!
I'm trying to run amp wires through the firewall too. How did you guys fit yours in through the hole behind the fuse box? I tried to, but the existing wires are so thick they take up all the room. Anyone have pics of how they did it?
1 - 10 of 10 Posts
