hotrod said:
i'll trade. but you'll have to tell me how to take the cluster out. i haven't bothered looking it up yet so no clue.
this is perfect...because for some unknown reason i trust that you'll actually send them to me and i won't get shafted. i guess you just seem like a trustworthy guy!
anyway, to take them out is very easy. just do the following:
remove the six or so screws from the top plastic piece right above the gauges. next, peel back the rubber strip that goes along the bottom. it's flexible so don't worry about breaking it. after that, there is the little plastic strip that separates the tach/speedo cluster from the gas/temp cluster. the screw for that is right above it, remove it and pop the plastic piece out. after that, there are four screws around the gauge cluster, two on each side. there are non on the top and bottom. once you have those out, the cluster should be loose, except for the 6 or so plugs going to it. unplug all the plugs (three that are on the left side stay attached to the cluster but get removed from the piece they connect to on the dash). it could be a bit tricky because you sort of need small hands...just get your wife to do it. anyway, i had trouble getting the cluster out the first time i did it, but have faith because you can get it out you just sort of need to push the bottom part of the dash down a bit to get it out of the way. it's kind of tight but they'll come out.
