ummm. what motor, and what cam?I installed a stage 2 cam a couple days ago and my power is worse than it was before. It flat lines at around 3000. No pull. Could this be valve float? Ignition? not enough fuel?
did you tune the cam. are you running a stock ecu? did you do valvetrain work to use the cam. did you extend the rev limiter to the operating parameters of the cam?Comp cam 59300. D16y8 bored .5 over with a shaved head and ported polished.
what does boost have to do with your valvetrain. typically to take advantage of a more aggressive cam you need to do to things....up your comp ratio and extend your rev limiter....the stock valvetrain isn't the best idea for such a thing. and why are you running the car untuned?The install went fine and the engine sounds great. I have the stock ecu. I didnt use valvetrain work because i have heard many people who have boosted with this cam for years with no valvetrain work and they never had problems. The rev limiter is stock but i should feel power before than anyway
on a map car it could be worse. hence why you have to re-tune whenever you add any parts. are you throwing a cel. do you have a cam gear?I agree that i wont seas good as results without a tune but the car shouldnt be WORSE than it was before. And stock injectors should be more than enough to support anything besides forced induction. I already have NGK plugs. I also played around with the distributor to no avail
why would you put a "stage 2" cam in the motor if you're gonna boost it and you don't even have a cam gear? what other mods do you have on the car. you should really upload a car and parts list like the rest of the membersIm running untuned because it is not worth it to get it tuned yet and i plan on boosting soon, so im waiting
felt gains? like with a butt dyno? a cam gear lets you tune out valve overlap which is what n/a cams cause. more aggressive cams have more overlap. overlap causes boost to shoot through the head and be wasted. the best cams for linear turbo power are usually stock cams or turbo cam.Everyone else i read who bought this cam felt gains. There is no CEL and i dont think a cam gear is worth it for a single cam
1. you talked to people? did they show you a dynograph before and after this cam was installedLike i said, i talked to a few people who have boosted with this cam no problem. I just posted my parts above. Im not looking to upload a parts list nor do i have the time. I just wanna be in and out. Im just looking for some suggestions
