1 - 20 of 47 Posts
Mods List
1996 Civic DX Hatch
Engine Mods-
B18C5 engine (Type R integra)
81.5 mm endyn pistons
skunk2 intake manifold
Stock valves, springs and retainers
AEM CAI
DC sports 4-1 Header
JDM LSD Transmission
Port and Polish head
mugen head gasket
ACT Stage 2 clutch
AEM fuel rail with pressure regulator
Interior Mods-
Sparco seats with belts
4 point Roll Cage
ITR rear seats
SI gauge cluster
Suspention MOds-
CTR 5 lug suspention
Tanabe coil overs with shocks
DC sports lower tie bar rear
Dc sports upper tie bar rear
Dc sports upper front strut up
Rear upper hatch support bar
Exterior Mods-
CTR Wing
VIS CF OEM Hood
VIS CF side skirt OEM style
VIS CF front lip Mugen Style
VIS CF rear lip OEM CTR style
CTR Championship White paint job
CTR championship white 5 lug wheels
Violet HIDs
CTR style black housing head lights
CTR foglights with violet HIDs
Sparco hood pins
Discussion Starter #6
Jree$e said:
nice ride..:tu
what kind of numbers you putting down?
i havent be able to run it yet.. still breaking in the motor-- fresh out the machine shop! :w00t
clean ride.
not diggin' the steering wheel though.
But why are you keeping a full interior with a roll cage? why don't you just gut the car?
Discussion Starter #9
TaQ said:
clean ride.
because i need a little bit of weight in the back. honda's are know to be front end heavy i learned that with the coupe.. cause it gutted and somtimes the back end kicks out.. i dunno i thought it looked better that way too!
Super Ban-Finger Mod
you say that like it's a bad thing.
oh and you should REALLY wrap your harnesses around the cage behind you. the shoulder harnesses should not exceed 5 degrees below or 30 degrees above the horizontal. in the event of a crash, the shoulder harness will not adequately protect you and will most likely cause a spinal compression. also, if you don't have a fifth point (aka crotch belt), there is a likelyhood of you submarining....in other words, your body will slide under the lap belts and end up as a pool of crushed body parts on your floor pan.
Looks good, who did the work???:tu
that is my next dream car/project... :clap
Absolutely perfect!~
Discussion Starter #20
trick did some of the motor and wang's did the tuning/ a machine shop in lawerance built both blocks.... ummmm Motion Motor Sports did the body work and painting
thanks!
1 - 20 of 47 Posts
