ok just got a after market radiator (mine is leaking) and it came with two nipples for the tranny cooler for an automatic car.
question 1. can i use the tranny cooler section with a "golden eagle oil cooler adapter" ?
question 2. will this overheat the radiator ?
pro's? con's ? thanks !
u wanna use that to cool your motor oil?
if you have a stick and you plan on doing that dont even bother.
why not ? im pretty sure atf fluid gets almost as hot ....
