nitrous
Run plugs one to two ranges colder than stock (they will dissipate heat through the head better lessening the chance of detonation) also raise your octane to at least 100 (NOS makes a booster good for about 7 points) the lower the octane the more volatile your fuel making premature ignition from heat more likely. This will allow you to run your 75hp shot, if your still uncertain retard about 1 degree.
