Like NOSGSR said neither of the too are necessary. If you plan on racing at night, the bottle heater is helpful because you can use every ounce of your bottle efficiently. The purge is beneficial if you are one of those people that drive around with your bottle ready to go. That way, at the end of the night, you can turn off the bottle and vent the line without inhaling it by opening the fitting.
