First off thank you for any help in advance!!! I have a 97 passport and it has sat for a bout 2-3 weeks, when I went to run it the clutch pushed down and felt normal but does not disenguage. I changed the slave cyl and still same thing. Any help would be appreciated. By the way I had the clutch changed about a year ago to a six puck HD clutch and at the same time had my flywheel resurfaced.
Super Ban-Finger Mod
did you properly bleed the system?
have someone depress the clutch pedal and take a look at the slave cylinder...if it moves the fork, then there might be something wrong w/ the pressure plate or the throw out bearing might be out of whack or something else inside the clutch assembly.
