Okay, I have an issue with my cooling fan on the radiator. I have a 1993 Del Sol Si with the D16Z6 motor. It is a manual transmission and does not have A/C (from the factory.) I have changed out all the sensors connected to the cooling system. There are three of them. I have replaced the radiator and cap. I have replaced all of the hoses and hose clamps. I checked the cooling fan by running 12volt current through it and it spins. When I hooked everything up to the motor and got the engine up to temperature....nothing. I waited a good 10 minutes. Nothing. No fan at all. I swapped the relay for the cooling fan for the defroster relay and that didn't help. I hear what sounds like a switch clicking and the motors slows a bit....but the fan just stays still.
Any ideas?
I am stuck
Any ideas?
I am stuck
