1 - 8 of 8 Posts
sup guys, im new here mostly because my speedo stopped working a month or so ago and its starting to really piss me off. VTEC still works. I've heard VTEC wont work without moving and it needs the VSS to work to sense speed, so im guessing its the gauge cluster. help me out!!!!!
Have you taken a lookk behind your gauge cluster to see if all the wires are plugged in? I know this sounds dumb, but check the easiest stuff first...
Do the other gauges work properly, gas temp, RPM's?
· Super Nazi Mod
yeah cause wires just fallout all the time :nuts and I wouldn't exactly call it easier to get to compared to taking out the vss and replacing it. especially since thats the problem
oh and vtec works fine without a speedometer, it won't work without the rpm.
Discussion Starter · #5 ·
thanks guys, im probly gonna get a different vss first. do you guys know where i can get a vss the cheapest. this car is just a beater, im not looking to put the best in it. you guys know what i mean....
your vss isn't making the proper connection
Clean em with choke cleaner and see if the plug and the progs in the vss are cleaned well , see if that works
if it doesn't its not making good contact anymore, take some speaker wire and open it up, put some of the wire in each of the holes and plug it in again, should fix it
vss's dont go bad, just the connections do. its probably old and needs to be cleaned off really well.
· Super Nazi Mod
not always true. I have seen them go bad. and it wasn't the connectors. but I would say 75% of the time it is the connection and a good cleaning normally fixes it
1 - 8 of 8 Posts
