What are the normal temperature readings for the Civic VX A/C? I used a therometer to check mine and during the day its at 68 degrees idling, with 62 degrees running.
At night the lowest I've gotten was 51 degrees whereas the average is 56-58 degrees.
It should go under 50 degrees because it is R12, but I don't know what's up.
IISaiNtII said:
the ac will only get about 25 - 30 degrees lower than the outside ambient temperature
most hondas i seen have crapp ac systems...once they get older. not like my s10 truck that makes it feel like a freezer.
hondas ive seen usually get about 50 degrees.
true.
