1 - 8 of 8 Posts
im new to nos and have read a few of the threads but still have not found out how to set up an auto with nos being that sometime rpm levels jump and i dont want that to happen while spraying so is there a way around that problem
you would run an rpm based window switch to ensure that nitrous only sprays from say, 3000 up to about 100 rpm below your shift point.
what does your accord run on the spray?
bonestock94 said:
i ran a window switch and also ran a tranny oil cooler but still blew out my auto tranny. glad i converted it to 5spd.
bonestock94 said:
no track times of it when it was auto.
only went once after the 5spd conversion and it went mid 14's w/ 75shot, full interior w/ some mad wheel hop and really shitty 60 ft.
mid 14s in an accord? wat u got in there now anyways? any internal work? cant be stock with nitrous running 14s with bad traction? :number1
i heard running a windows switch can actually be harder on the motor itself rather than just letting it run through the gears...its like a shock cutting it off mid shift and then having it spray again. the guy thats putting a kit on my auto said my 55-75 shot would be fine on my auto and stock bottom end, although it is a JDM h22a haha prob gonna handle it better than an f22 tranny..but im still considered a noob i dont know shit
now its turbo but off the street for now, making solid rear and side mounts and putting on an hondata IM gasket.
back then it was just i/h/e 75 shot w/ spare, subs, and amp out. i wish i would have ran a few more times with the spray. this guy w/ a same f22b1 engine and a slightly heavier CL chassis pulled a low 14 on spray w/ i/h/e and 23" m&h.
these f22s are stout...
1 - 8 of 8 Posts
