I got my 94 integra ls vtec and my car wasnt starting. It sounded like it was starting but never turned over. I bought a new dizzy and it is still doing the same thing. Someone please help me and tell me why my car wont turn over
have you checked to see if your getting fuel? fuelpump turning on? are you getting spark? do you have compression in each cylinder?
Did the car run in the first place? or did you just buy it this way?
check compression! i had the same problem!. my exhaust cam was completly off from top dead center so i was losing all my compression. . make sure everything is at TDC! check if your engine is getting FUEL AND AIR.and if enough..without either your car wont start!
