hey whats up? i have a99 accord 4cyl f23a4, with a aem cia, and airmass header, testpipe, and 2.5 bolt on exhaust. my problem is when i replaced my cat with a pipe(with o-2 sensor attached) the check engine light comes on and stays on, so a guy from kteller(on hondatech.com) suggest i get a o-2 simulater, so i do, an ecg test pipe o-2simulater. I had a tec at honda install it for me, but the instructions are for the f23a1 engines in the accord. The simulater didn't work, so I sent it back to kteller with no problems
, got the second one and still the check engine light comes on, :mad and I ve had the ecu checked for codes just in case, its the 2nd o2 sensor. So I have four questions. 1. Has any one used this o2 sim, and on what engines, has it worked or crapped out like mine? 2. Does any one have the wire configuration of the ecu that is in my model car? so I can double check the work of the tech. 3. does anyone think that the engine difference will make it incompatable? it shouldn't the instructions say accord 98-02! 4. is there any other way to alleiviate this problem,maybe a highflow cat? I hate having a check engine light blaring in my eye :eek , especially when nothing is wrong!
thanks
thanks
