I plugged a scanner to my car and I saw two odd things.
First....primary 02 sensor voltage was bouncing around like crazy at an idle (warmed up idle at 670 rpms). Going from ~.2 to ~.7 and back almost like clockwork....I know the sample rate is slow on most scanners but it's odd that it bounces back and forth.
Second....the secondary 02 sensor voltage was completely static at 1.275v. Didn't matter what I did (revving), it would read a fixed voltage. Is this right?
I don't have a CEL but I have been battling a knocking issue for a year or so at low engine speeds, high load like the PCM isn't retarding the timing enough so that's why I put the scanner on there to check timing under certain circumstances as well as see if I'm getting a weak MAP signal. The base timing is perfectly at 12deg though.
Any thoughts are appreciated.
