I am trying to place a 92-95 H22 in my 97 Accord. Where can I buy a harness to convert my OBD2 Accord harness to the OBD1 H22 ECU? How much?
sorry, I don't know the answer to your question, but I figured this would be a good place to ask what the exact difference between OBD1 and OBD2 is
Anyone know?
first, dominate9, check hasport(www.hasport.com) they have it, second, scottigee, OBD stands for on board diagnostic, and its incorporated into your ECU so when something is wrong w/ your car, the tech can hook up a scan tool and take lots of different readings from different sensors in the car and check codes to diagnose what is wrong w/ the car, the difference between the two is basically sophistication, OBD II has more sensors, and can give the tech a better idea whats goin on, but OBD I is more tuner friendly and thats why most guys get OBD I ecus, also because all the major ECU tuning companys make OBD I ECUs or will only tune OBD I ECUs, I hope this explains everything
Discussion Starter · #4 ·
unfortunately, there aren't any harnesses on www.hasport.com for Accords
I would say try ww.skunk2.com, they have them for the accord but I don't know the exact year you would need. If all else fails just call them, there really cool and if you leave a message for them to call you back they will. I'm using there harness in my teg and it worked awesom for me to run a 95ls ecu. I have had no problems and my car runs a lot smoother, it is definantly a conversion I recomend doing if you tired of all that LEV emissions and sensors bull****. Once you do find the correct harness it is all plug and play, nothing to cut or soder or any of that crap. Give them a call, if they don't have it maybe they can point you in the right direction...
