I read on the following link that you can't properly dyno an OBDII car. It meantions something about the ECU adapted to different areas of the map depending on your driving style.
Check the link out:
http://member.rivernet.com.au/btaylor/BMWText/technical/WhyYouCantDynoOBD2.html
This is an excerpt from the link
See, previous to OBD-II, adaptive information was stored in
battery backed SRAM. Unplug the DME to swap chips and woosh
all adaptive factors set to "nominal" (1 for mult. and 0 for add.)
Then came Kalifornia, and KARB, and OBD-II.. and EEPROM for
storage.. this means you can't just "erase" it anymore because
the last thing the DME does during shutdown is write the SRAM
locations to EEPROM.. and guess what the first thing it does is.
Yup... zero SRAM, run a galpat memory check, and reload the
needed ram locations from EEPROM.
The only way to clear the adaptive locations is via diagnostic
commands down the serial port (even desoldering the main
FLASH memory program store doesn't do it, because there is a
separate EEPROM elsewhere)
So if you can't clear it.. you can't do an apples to apples
comparison.
What's worse is the "quasi-tuners" out there who have no idea
how it all works, spouting nonsense..
Either you trust the person your buying it from, or don't
buy it. It really is like "Natural Flavors" in soda...
Either you trust the manufacturer, or you put the can back
on the shelf, because it's not easy to quantify the contents.
I'll take my "Natural Flavors" in Surge or Mountain Dew flavors
(Unless you carry Jones Soda, and then I want rasberry!... YUM!)
Now.. back to adaption.. since you can't clear it
you can't get a valid comparison.. want to try something..
Take your car.. OBD-II.. chipped or stock.. drive it one week
like a MADMAN and dyno it.. then drive it for another week
very meekly.. and dyno it.. compare the results.. and they
WILL NOT be anywhere NEAR the same.. and we didn't change the
car at ALL..
Why?? (Prof. Shark asks the class)
Exactly.. the car ADAPTED to different areas of the maps
and either enrichened or enleaned the overall mixture.
Now.. in whatever state the car is in, you can be rather
assured that ON AVERAGE the chipped car is making significantly
more power than the stock car.
Adaption works like this.. at lower loads and rpms it watches
the AVERAGE correction (realize we swing rich and lean of
stoichiometric continuously, except for WOT)... and it adds or
subtracts a bit of fuel until the low speed fuel mixture is
swinging evenly around Lambda = 1.0 / AFR 14.7:1..
Now as the rev range increases.. we switch to a multiplicative
correction which adjusts (if you will) the SLOPE of the fuel
curve by multiplying the STORED values by a factor (based on 1.00)
Depending upon how good the manufacturer tuned the low end and lower
midrange, the environmental conditions, the fuel you are using,
and the flavor of soda I have in my fridge (*grin*) .. well really
what AREAS of that lower speed area you are in most of the time
during the drive cycles.. that determines WHAT those two magic
numbers will be.
The kicker.. and bummer.. is that even though lambda control isn't
active, and adaption isn't HAPPENING at high throttle angles, those
two numbers ARE STILL USED IN THE CALCULATION regardless as an
"overall correction" to fueling.
So.. let's say that at 20% throttle and 3000 rpms the manufacturer
is a bit rich.. the system adapts lean.. if you drove at very light
load/throttle for a while at 3000.. you might see your peak HP
drop 10HP on the dyno.. once the car adapts
Conversely, let's say the manufacturer is a bit lean at 2000 and 50%
and you spend your week in LA traffic jams always gassing it in 4th
and not downshifting.. car goes rich.. now you dyno your car and
BOOM magic horsepower have appeared (well.. not really)
Simply put.. while any chip manufacturer can tell you that 90+% of the
time your chipped car will have more HP than the stock one, unless you
have cleared the adaption BOTH times when you run the cars you can't
quantify it at all.
Check the link out:
comparison.
car at ALL..
numbers will be.
quantify it at all.
