ok i have an obd2 b16(00 si engine) in a 89 civic hb,the wiring harness,dizzy,and ecu are all obd0, i want to be able to run hondata and have my car tuned.i want to change everything to obd1,i have the ecu(95 del sol),piggyback harness(obd0 to obd1) for the wiring ,and the dizzy(95 del sol). so now my question,if i put all of these things on my engine will my obd2 b16 run properly and to its full potentical? if not how do i go about changing my car to obd1 the right way?
if you have a p28 then dont use the same dizzy on your b16.
what im saying is, if youre getting your ECU from a 95 Si sohc vtec model, dont use the sohc distributor for your dohc engine. and if you get the ECU from the same car, it will be a p28.
