hi,
has any of you used these cam gears and have any info or input that that you would like to contribute as i am about to get these cam gears. what other cam gears do u recommend. I'm getting these together with my jun stage 2 kit!!.
they reckon i can get 250hp from the kit, do you think its realistic??
i have a mugen full exhuast and air intake and vtec controller. what do u think i will get with the jun kit??
thanks
Discussion Starter · #5 ·
Thanks guys...
lucky i asked, otherwise would have wasted all my money. i'll probably stick with the jun cam gears then. AEM and SKUNK will ocst the same by the time they convert to aussie dollars!!!
hey, whatcha all think about the Jun kits?? im getting them. Unless i hear something bad about them. my goal is about s2000 ass kicking 250hp!!
Skunks
The skunk gears are lighter than the AEM and have more nuts for less risk of slip.
What's the deal with this Jun package? you say stage 3, is it a turbo kit? What does it consist of? Only for h22 right?
What kinda aftermarket does jun offer for the h23?
Late
Discussion Starter · #7 ·
ots not turbo...just valve train components..
the packeage im getting are stage 3 cams, valve spings, titanium retainers, cam pulleys, and maybe a jun ecu.
the best set up for this is to increase the rev limit to about 8000 cos the max power on these cams are 7680..250hp, 257nm
i think they make it for ur car h23
check it out...
www.junauto.co.jp
