I came across this info on another forum and copied the info here. It was just too good for it only to reside in one place. Thanks to Sonny who originally posted this information on HT.
You may want to play with the D-series compression calculator after reading this post :
http://www.knology.net/~jediklc/D.htm
You can click here to See a Diagram of Piston Specs.
Additional piston specs are available here : http://www.superhonda.com/forum/showthread.php?postid=1207532
Late Model D-Series Piston Archive is available here : http://heeltoeauto.com/httech/YaBB.pl?num=1160787887/0#0
Sonny said:
Hi All:
So far, I have 6 different D series pistons to work with. I have almost every piston from 1.6 liter engines. I think I'm missing one from the 96+ Civic HX, but nobody has that car. :p
Here are the contenders so far:
I've measured the P29 and PM7 pistons in several ways and as far as I can tell, they are exactly the same. I wonder why Honda made 2 different part numbers and castings for the same piston? Hmmm...
Sonny
Discussion Starter · #2 ·
Sonny said:
The main motivation behind this project is to determine what compression ratio is yielded using different combinations of D series pistons and D series heads. There is such a large variance in the way that Honda designed the pistons that just about any compression ratio is doable.
For example, the PG6B (86-87 Integra) and the P28 (92-95 Civic) both have the same compression height (1.181"). They will be flush with the top of hte block when installed. However, the Integra piston has a small dome, but the Civic piston has a HUGE dish. The difference between the 2 pistons afa compression ratio is very large.
Here are some pics comparing the P29 (88-89 Integra) to the PM7 (88-91 JDM ZC). This Integra piston was slightly modded on top, but I've seen a very clear picture of the top of this piston and can say that it is identical in shape to the PM7.
Sonny
Great, the one piston he doesn't haev is the one I need to see. :cry
*wink*
we got all the good stuff. =)
kommon rocks for the effort he puts in here. u guys should love him.
