does it have to be air tight? or not, do you have any pics of your set up you can share? thankscspina said:An oil catch can will be routed either between the crankcase breather line and the intake manifold, or the valve cover breather and the intake take pipe up stream of the turbine ( a vacc only source). As far as the pcv line where does it tie back into your intake, that would be the big deciding factor. PS don't buy an expensive catch can you can make one buy using a fuel filter, from any auto parts store, I have been using one for a few weeks it works great!
What exactly did you do for the custom catch can?cspina said:An oil catch can will be routed either between the crankcase breather line and the intake manifold, or the valve cover breather and the intake take pipe up stream of the turbine ( a vacc only source). As far as the pcv line where does it tie back into your intake, that would be the big deciding factor. PS don't buy an expensive catch can you can make one buy using a fuel filter, from any auto parts store, I have been using one for a few weeks it works great!
