97accordsir said:
dude, I don't have the car manual cuz mine is just a swap. and I don't have a lot of knowledge of H22a. So what will harm if I am using really heavy oil. is 15W50 really heavy??? I don't really think it is. cuz some of my friend using 20W50 in their type R. and lot's of ppl said using a bit thick oil in older engine is better to prevent the wear. isn't it??
:fire1:
Those weights (50w and above) of oil are generally usd as racing oils, because of the sustained and constant high temps seen in those engines.
If you use too thick an oil, then you may not get it to flow properly (at least untill its warmed up, like in a race engine, think stock cars) to areas that need to be lubricated, and then those parts will degrade faster.
I'd say for all around, 5w-30 would be your best bet, and maybe 5w40 if you run it in high temps for extended time periods. It does get cold there? So a 5w will be good.
And about the oil going dark really fast: it is normal for oil to turn dark within the first thousand miles. This are just the detergents in the oil cleaning the engine deposits. Color of oil is by no means a reliable or good way of determining if the oil is still good. If you are really worried, get an oil analysis done. Oil will last you at least 3,000 miles under normal driving, less with constant hard driing or racing. If you race (roadcourse), you should change it after each race anyway.
Also, im sure you know this, get a quality filter, do not go with fram or oem honda. Get a bosch or mobil 1 or purolator. Anything but a fram. BDC can contest to this.
http://www.ntpog.org/reviews/filters/filters.shtml
http://www.dorianyeager.com/oilfilterstudy1.html
http://forums.audiworld.com/a4/msgs/336510.phtml
