silver4banger said:
i have oil leaking into the far left spark plug. what can i do, how can i fix it, and give me a guesstamite on how much it would cost. thanks a lot!
not going into too much detail but, this is how you do it, hope this helps. please correct me if i made an error.
1. take your valve cover off, using a 10mm socket.
2. replace the o-ring on the inside of the valve cover that you think is leaking.
3. replace valve cover gasket.
4. replace valve cover according to torque specs.
cost:
o-rings - $4.24
valve cover gasket - $9.13-$9.23
**please keep in mind that prices vary. i got these from an online honda parts distributor.
