hi, i just installed a sunpro oil pressure gauge on my base prelude and it works perfectly but now my oil pressure light is on and wont go away. any ideas why?
i wanted to keep the factory sensor on there just for this reason so i used a T fitting with the correct threads to do the install (see picture) if anyone could give me some direction it would be appreciated. should be noted when i relocated the oil pressure sensor i located it upside/perpendicular to the motor (as seen in picture to avoid half shaft) but this should matter i dont think. Also i used high temp silicon on the threads (grounding problem maybe? i doubt it) but any input would be great.
thanks
thanks
