ok, so is it true that the type r oil pump and gsr oil pump are different?
if so, does NE one know if the prelude type s oil pump is different from the j-h22a?
stronger oil pump=stronger engagement of teh vtec
I don't see why the type S engine would need a different oil pump from any regular JDM h22, i'd think they were the same.
Also I don't see how the oil pump has anything to do with VTEC engaging any harder. Care to enligthen me if im wrong.
vtec works most off oil pressure...the "selonoid" is really a piston in there.
the J-h22 vtec hits harder than a my stock 5th gen usdm-h22 did..by far..so i was wondering if the "stock"j-h22 vs the type s was ne different being that the cams are more aggressive compression etc etc wouldnt it make sense to have a stronger oil pump to push out that 20 xtra hp's
Discussion Starter #4
bump...someone gotta know for a fact?
Tien, someone by the name of "Keith" on PO did a thing on this with his JDM and usdm motor.
The oil pumps are the same. Too bad im not on there anymore or else I would of taken some pictures for you guys.
Discussion Starter #6
thanx dood, hey if i get looked at like im stoopid and dat the answer is the wrong answer imma come lookin fo joo
higher volume oil pump will rob you of some power.
Discussion Starter #8
yes but at the same time, it can add some, type r oil pumps are different from gsr.
some gsr got two stage vtec type r only has one, but a stronger oil pump.
ive been thinking that this might be *one* of the reasons why h23vtec's seem to spin bearings.
i have an h22 pump tho :tu
i think it does make vtec hit harder... it forces oil through the system faster i believe. this is why some people clean their vtec solenoid screen, so the oil can rush in and make the vtec snap
