All I can say is that I will be getting these. They are not stiffness adjustable, cause they don't really need it. they are made and balanced specifically for each car and besides, $650 SHIPPED is cheaper than a good set of springs and some Tokico illuminas. Kteller, a sponsor of this forum, extends the 1 year warranty on these by another year when bought from them. And they ARE rebuildable. I can't wait to get mine!
Omni-Power coilovers can be raised or lowered, up to 4in., from two separate positions which allows the user to raise or lower their vehicle without affecting spring preload or damper stroke length. We incorporated large 46mm pistons along with 20mm shafts which we found far superior to typical smaller piston/shaft coilovers. By using large 46mm pistons we were able to greatly reduce the stroke length, while still moving the same amount of fluid, resulting in unprecedented efficiency. All coilover systems include high grade aluminum pillow mounts further enhancing overall control. We used CNC Wound SAE 9254 Racing Springs which were found to be the longest lasting spring on the market that showed no tendencies to sag.
Sports spring (F=12K & R=10K ) Streets spring (F= 10k & R=8K) and damper rates that yield exceptional handling characteristics coupled with unsurpassed street drivability
Features
- Anodized Aluminum Shock Body
- Aluminum Pillow Mounts
- 46 mm Single Piston Shock Achieves Unsupassed Level of Control and Sensitivity
- 20 mm Induction Hardened Shaft Designed To Withstand Both Track Abuse As Well As Road Imperfections.
- CNC Wound SAE 9254 Steel Spring for Maximum Performance and Durability
Kits Available for
- Honda Civic EX, LX, DX, Si HB 1992-95 Street and Sports -- $649.00 shipped
- Honda Civic DX HB, CX HB, EX, LX, HX, DX 1996-00 Street and Sports - $649.00 shipped
- Honda Civic SI DOHC Vtec 1999-00 Street and Sports - $649.00 shipped
- Acura Integra GSR, LS, LS Special, RS 1994-01 Street and Sports - $649.00 shipped
- Acura Integra Type R 1994-01 Street and Sports - $649.00 shipped
