my other car, a 91 civic si hatch is having some problems. :mad it's winter here in wisconsin and there is a lot of snow. my car is one wheel drive and i don't know whats wrong! even when i'm on the snow i can't even spin the right tire, ever! it makes popping noises on the right side by the half shafts and cv's so it's probably a joint in the axle or something???? if anybody has advice on what this is please help me!!!!!! :confused
thanks
i wouldn't think it would move at all with a busted axle....
My thought is that it could just be a busted Half Shaft. Was it popping before when you would turn...I mean before all of this happened?
kommon_sense said:
doh... you are right... wonder if it is seized since an open diff should always take the path of least resistance.
its most likely axle or cv joint, or possibly a worn bore in the differential case.
right as usual :)
thanks
im sure its a busted axle. try driving and see which side its broken from..tranny side or wheel side.
The noise I would look into but with only one wheel turning thats typical of cars that have open differentials ( trannys)
